Was putting axles in, decided to service diff as well. Car feels way different in a good way. Drivers side axle was showing wear and tear.
then to my delight learned the trailer would clear the driveway slope due to it being flat. I thinking I could get used to this bougie life!
Was putting axles in, decided to service diff as well. Car feels way different in a good way. Drivers side axle was showing wear and tear. View attachment 100894View attachment 100895
then to my delight learned the trailer would clear the driveway slope due to it being flat. I thinking I could get used to this bougie life! View attachment 100896View attachment 100897
I just brought my drain pan back inside been sitting in the yard for few weeks airing out after brake clean and degreaser lol. Worst smelling stuff ever. Changed it a few months ago and then topped it off again a little while back
Friction modifier additive Is the worst I had a small bottle of it say 8 oz many years back even if you don’t spill a drop and throw the bottle out it will haunt your garage form months, cross between cat piss and gear oil be the nasty smell.
Keep in mind air charge temps start to pull timing based on the following values in the tune: View attachment 98234
You could move Part Throttle Ref IAT to 999 and it would never pull timing...
