LOL. So mh, that means you will be running your M&H's on a 13" or maybe even a 14" wide wheel?
I had an OL10.5 car in the mid '00's. We ran a 14" dbl beadlock w the "10.5x33-15" tire. The tire was actually 11" tread width and at 33" tall it had plenty of sidewall to allow for such stretch. They were a bit of a bitch to mount though, even w the dbl beadlock.
I can't even imagine trying to stretch these 305/45 MT's which is one of the tires this thread is about.
Seriously mh, I know a LOT about beadlocks, big tires and going fast and can't see your logic. Please enlighten those of us that are trying to 'look closer and more objectively' at this idea. Thank you in advance.
Pardon the delayed response I was off doing superhero stuff for my day job. No, I will not be stretching my 325s on a wide wheel; but I can show what it runs like on a 9.5" wheel vs. an 11" wheel - measured section width being but part of the equation. But, a rather important limitation with the narrow/standard body Challengers (less so for Chargers and widebodies). In the same way there is/was little data on the 28" tires collected in a single location, the same level of appreciation for information about mounted tires and their characteristics is absent.
The beadlocks are being discussed in another thread so that can stay there; I am far more concerned about the misconceptions about the effects of tires on wheels and how they respond. The video pretty clearly explains how different tires respond to mounting configurations. The rim diameter is the least of the concern as opposed to sidewall construction and response; however for the sake of conversation let's look at it.
Two diameter sets of M/T ET Street Rs - 17 and 15 inch wheels, in 28 and 29-30 inch diameters respectively:
305/45R17 (28.1 - 17 / 2) = 5.55" sidewall height
315/50R17 (29.4 - 17 / 2) = 6.2" sidewall height
275/60R15 (28.2 - 15 / 2) = 6.6" sidewall height
315/60R15 (30.1 - 15 / 2) = 7.55" sidewall height
I think we can all agree that more sidewall is preferred than not enough. I mean why wouldn't we all run 15" conversions if it was easy/cost effective, right? But, they aren't and so we don't. With that in mind: what does right look like? That is relative to the application; but, in such high powered heavy cars it is usually defaulted to "as much as physically possible". Unfortunately it is also unnecessary for one reason: chassis set up.
The cars running on squared up/stretched section width 235s, 275s, and 315s as mentioned in the video have way more power and tuned suspensions than your typical bolt-on portly HC, and perform exponentially better despite not having "enough" or the "right" tire. Why? Because someone invested the time and tuned the suspension to the car, I am not talking about bolting on parts here (a diff brace and a set of trailing arms don't a race car make) thus making the most of the tire available and making the tires respond despite having less than compliant side walls square or stretched.
Has anyone here tuned the instant centre and anti-squat in an IRS car? 4 links, ladder bars, hell even leaf springs, sure. All day (the Drag Pack cars come with solid axles for a reason). But, the factory HC IRS? Nope. I bet most folks wouldn't even begin to know where to start, much less how to alter it. So, we ultimately attempt to mask the inherent traction built issues into the factory HC suspension with the biggest tires possible, inducing weight transfer, and locking out the suspension (as camber gain is not ideal). This covers it pretty good:
https://www.svtperformance.com/threads/drag-racing-irs-in-here-need-tips.1070658/#post-15155552
To sum up, don't blame the tires - because those tenths and thousandths between tires is more likely a tuning issue (car and/or driver) than a fundamental failing in their construction, material, or design. They are all good options.
It's late and I am tired, but I hope that helps clarify or muddy the waters on the issue.
