2000 HP Twin Turbo Hellcat
Hey Colby…. Some things that I was planning to chat with you about but if I ask the questions here maybe someone will learn a little about doing stuff at this level. Your block has been a full fill. I assume you’re still pumping water thru the heads. What pump are you using and how’s that working as far as temps go with the methanol? Going to the Dart.. I assume you are not going to do any filling with that block. Going to use the same pump and radiator? I also assume you guy have had a good look at the Dart. What do you think and any thoughts on Callis Hellephant vs that? Congrats on the accomplishment. Your team has their shit together for sure. 👍🏼
Dman007
Dman007
6 Second Best E/T
Smyrna
2019 Charger Hellcat
Thread Starter #142
Hey Marc,
Going to methanol changes the game. We do not worry about IAT temps anymore. Methanol loves heat and burns better with hot air. But you will need 720 lbs FuelTech injectors and a Aeromotive 25 gpm crank driven fuel pump. That means building a gas tank in the front bumper :)
Don't use water because of the increased risk of lifting heads and water vapor locking cylinders. We're racing these cars not trying to split time daily driving or reconfiguring the car for Sick Week. The events like Streetcar Braggin Rights (Heavy Weight) and other Heavy weight events don't care about water. They want to see big heavy cars running amazing numbers and competing.
As far as the Dart block...holy cow...I have not seen anyone besides the aluminum blocks say they can make 3,300 horsepower like Dart can and it's a cast-iron block. Plus if we went with an aluminum block, it would exclude us from some events like All Steel All Glass or throw crazy weights on the car.
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #143
Marc,
Jake Sampson and the Dart engineers are discussing if we will or won't fill the block.
Marc,
That is one of the questions we were wondering. That’s a considerably heavier block and with the 1/2” studs might be safe to run the coolant. Did Dart say 3300? Damn 😳
Trackhawk, Turbo Mustang, RS3, Golf R
I was on the fence buying the dart block but it just seems so dam heavy. Why not the TKM block or is that because it will limit ur class racing?
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #146
Yes they did and that's why we choose them
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #147
The Demon TKM blocks are just the BGE stock block like we have now.
If you're referring to the Noonan aluminum blocks that Demon & Noonan partnered on....oh no, the price compared to a Dart block (6k compared to 17k...not worth it) and then aluminum blocks are not allowed in some classes
I was referring to the cast aluminum Hellephant block being made by Callies now. I was talking to Geoff Turk at Blackbird and he recommended those. About 100 lighter than the Dart. I had no idea that Dart was saying 3000+ hp
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #149
I just hung up with Callies. Here are the data points to make decisions:
1. Power: cast aluminum blocks are not as strong as cast iron blocks. Thus the Dart block is superior for maximum power.
2. Weight: Callies block is 100 lbs lighter then Dart. Thus Callies gets it on weight.
2. Cost: Dart is $6k and Callies is $10k. Thus Dart gets it on price.
3. Timeline: Both companies are 8 weeks out on new orders - so equal there.
Summary: Dart blocks wins it for me. More power, more reliability and cheaper. Plus the front end of our car keeps lifting and +100 lbs would help balancing the overall car.
No sorry should have been more specific I was referring to the Demon TKM Billet Aluminum watered block. I would have assumed ud have chosen one of those cause money doesnt seem to be an obstacle for u lol..... But I get the whole class racing thing. Geeeeez thing is cooking! Good for u!
I had a chance to take a close up look at one of the Darts last night. That 3300hp number from Dart meant we HAD to pull it out of the box and see what is going on. There were a number of wows. Impressed to say the least. There are two versions. The VVT based on the 6.2 Hellcat and non-VVT based on the 6.1 (the one we have). The block itself is said to weight 30 lbs more than the BGE. That’s a lot of beef added where it’s needed and you can see it. Along with the splayed main caps and water passages (didn’t see any need to fill those). One place I see to get some of that weight back is one of the billet front covers from Blackbird for the 6.1. Because we’re going turbos… that non-VVT 6.1 version means that the heavy 6.2 cover/water pump contraption with all the pulleys can be eliminated. That’s probably a 30 lb weight savings right there. My filled BGE is in assembly right now and the decision was to stop and reevaluate. With this Dart, my 2500hp goal would be a one and done deal. I can have that 6.1 right now for $4900. Hmmm 🤔 Anybody want a a early half fill 6.2? 😂
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #152
that is the Noonan aluminum block....and that block is going for two or three times the dart block. Not worth it in my opinion.
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #153
Good stuff and I'm just sharing knowledge that was given to me.
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #154
The extra weight helps ur car but it doesnt for most and adding a 100 lbs to the front end isnt a good option for most compared to the Aluminum block considering the dart block weighs 20-25 lbs more than a BGE. They will probably make the same power I suspect or close.
Its $14k for the TKM Hemi Hellcat watered Billet block. Its $10k for the Dart block its not 3x as much. I think ur referring to their other billet Hemi blocks which are more expensive.
But cant wiat to see how far u push the dart block tho!
Dman007
Dman007
6 Second Best E/T
Smyrna
Thread Starter #156
We just bought a Dart block so we know it's 5k. Where are you seeing 10k, please post the link.
Here are the new Dart blocks all over different websites:
https://www.dartheads.com/product-c...-3-hemi/cbd-4-090-in/dh-9-250-in/cl-standard/
https://www.summitracing.com/search...p7-XyXQt1VBqhCyccCI9TKeShsOs0qUAjqRm2Nvv_vVSa
https://www.google.com/search?q=dar...g1Njc3ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8
The Demon Performance/Noonan aluminum blocks are 14k or more and then the Visner blocks are over 14k as well. So it's almost three times more expensive to buy a billet Gen3 hemi instead of the Dart block.
