Can a power steering car be changed over to the newer electric steering rack? I understand the elec. steering cars have different modes, not really concerned with that. Just wondering if you put power to the rack will it will work. Thanks MIke
you may be right. I was hoping it would be as simple as installing the rack and powering it up. And maybe the rack has a default mode as long as it has power.
My 17 Hellcat had no extra wiring for the EPS rack. I would count on the EPS being tied to everything on the CAN bus, as you can adjust the steering weight through the SRT menus.
May want to double check on '11's having electric steering. I bought a 2011 SRT 392 brand new, and it had hydraulic steering. Not a big deal, I personally have not heard of any Challengers having electric steering until either 17 or 18....
No idea what the electric steering gets its signal from.....almost has to be either steering shaft or wheel position?? Seems like something so important should be its own stand-alone system and not go through the ECU with 1000 other things...now I'm wondering how it works! lol
Most EPS systems use a steering angle sensor, and some type of steering torque sensor. Engine speed and vehicle speed are typically inputs used to adjust assist.
