"Project Demons Breath"
I ordered this car July 2017 and picked it up may 23 2018. . I immediately installed a URP fender mount oil catch can and a K&N drop in air filter. I put 1500KM`s on the car then installed the demon supercharger. I then drove the car to OST dyno and had it dyno tuned by Mike.Micah installed a set of ID1050 injectors at the same time. I installed a set of 3.09 gears, fastman 99mm throttle body,Gforce drive shaft, Bwoody race Aux heat exchanger, rear seat delete kit, a few different sets of rear rims and tires, Bwoody Aux Tensioner, metco idler pulleys. With the combo I managed the best of 10.09@138 in the fall of 2018.
Over the winter I removed the Bwoody Aux heat exhanger and Aux Tensioner, 3.09 gears and reinstalled the 2.62`s . I installed FI supercharger spacer/blanket kit, BMR cradle lock out kit, Demon coil springs, swaybars,.............(more info to come)
This is a slow but steady build up of my 2018 plum crazy hellcat challenger A8. My idea of this car it to build up horsepower with supporting mods, run a 9.99 at the track while doing it all on pump gas and looking dead stock.. Can I do it? I'm not sure but I'm going to have fun trying! I picked the car up on May 23 and immediately installed my UPR fender mount catch can, K&N drop in filter, metco oil filler tube breather and metco idler pulleys . I'm not going to bother posting much on them because they are basic upgrades that everyone seen a million times. Then after driving my car for a week or so and putting on my break in miles (roughly 1100 miles) I took the car to the dealer for my "break in inspection " . Then I installed my 3.09 gear set with differential brace and 1 piece aluminum G force driveshaft .. Nothing new there it's been done a million times also . I found a big difference for street driving ... very happy so far with the upgrades ..
I tried a fastman 98mm throttle body but I kept throwing a P2173 code every 80 miles or so. So I removed it until I got my unlocked ecu back from HPtuners .
https://www.hellcat.org/threads/project-demons-breath.211283/
Thread Starter #2
I was cleaning out a cupboard in my shop and found a few sheets of DEI Reflect-A-Gold heat barrier . Soooo I figured why not . I figure it can't hurt . I'm trying to keep the aircharge cool.Plus I put a thicker foam seal on the bottom of the air box . I have enough to do the JLT air box once I get it too .
Check out the bling!!
Blkout
Warner Robins
10hp from the bling alone.
Murfreesboro
2016 Hellcat Go Man Go
That space shuttle life :)
Markp
Fuck Trudeau
Who are you?....Gold Member? LOL
SpecOps Veteran
Fayettevile
2019 Hellcat Charger, 2021 Hellcat Durango
Interesting. I’d be curious to see if your temps drop.
Lol I was going to say king Midas or Francisco de Orellana but yours is funnier .
Me too . I have data logs from the unwrapped box so it will be interesting to see if it makes a difference. I will post results .
Lol. If that's the case I better get more
Good enough for NASA good enough for me lol
SNeal5966
'19 Scat Pack Challenger
Man...maybe that will be the first Hellcat in Orbit....didn't Musk put a Tesla into orbit?? Why not put a Hellcat too!
I will do it.......... On pump gas !
SNeal5966
Awesome!
Btw....in all seriousness where do you buy that stuff?
oilburner
coboconk
Sent from my BBF100-2 using Tapatalk[/QUOTE
I better bring my sunglasses for grand bend;):cool:
Awesome!
Summit racing has it . But I'm sure other places sell it too . Here is a pic of the details from summit . You can get small pieces too if you want .
You know the space shuttle blew up for a reason. That could have been it...
Thread Starter #17
No I checked into it . It had tesla parts on it . I'm pretty sure that caused it .
Thread Starter #18
Do you guys care about flow ratings of the 3 different setups? Or just track data ? I have access to a flow bench .
I don’t need no stink’n flow ratings....,
Demon1
Naples
2018 Dodge Demon
@Hpindy Thanks for continuing Project Demons Breath over here. It's great to follow.
The same with @Speedy!
Real world info keeps interest going.
