Who is running pump e85?
I'm running the ID 1050X injectors, are these too small for a E85 setup? Running the hellraiser 2.72. In first gear I was pulling 13.7% DC and at the end of the run 62.6% DC for pump 93 with two gallons of race gas thrown in for insurance (not the final tune).
I know you asked @Speedy!, but I'm going down this road too.
At first my thought was, "Hell, I don't know, I'll let others answer."
But you may have the answer already yourself???
Take your 62.6% DC and multiply by 1.3. :unsure::unsure::unsure:
I still don't know, but this is at least a simplistic approach to guessing at an answer.
:confused:
:confused:
Thank you for the reply, any knowledge is good knowledge. So it would put my Inj. DC at 82.29%. Might be at the threshold of needing new injectors. Where did you come up with the factor of 1.3? Is that a mathematical figure of how much more E85 you use over 93 or race gas?
Common knowledge on the increase in fuel consumption from "gas" to ethanol, BUT it is a generalization and I do not know how applicable it is in this scenario...
Djason
Beach City
2019 Redeye WB
I would error on the side of caution...put larger injectors in. Not sure what the professional group consensus would be but I think pushing the 1050's (which I have as well) to run e isn't something I would chance. I plan to one day get with Curt on a few changes but for now, with my work load, and current enjoyment on 93, I'll enjoy as is.
Chuck
Auburn
2021 Redeye Super Stock
I have a set of ID1700 that I had sent to ID cleaned and tested I can make someone a great deal
Shoot me a PM.
white1
Prairieville
LA
2020 hellcat charger widebody
Im running FIC 1000cc injectors with a 2.79 upper and want to say Im about 58-60% injector duty cycle so the 1050s should be fine
Im on pump e85 which generally test about 70% around me with fore dual pump setup
This gives me hope that I won't have to do a big injector upgrade, just put the 1050's in. I don't plan on going any smaller in pulley size. I currently do run a BAP but have been told for E it is a no go. Would this fuel pump be enough? https://highhorseperformance.com/hhp-racing-dual-pump-hellcat-returnless-fuel-system/
Its cheaper here when you take out the in line filter option
2015+ Stage 1 Hellcat Fuel System – Tapped Performance (myshopify.com)
Speedy ended up pushing his 1000's to the max and eventually upgraded IIRC.
I'm using FIC1200 and may need to step up a size if we pick up too much from the blower and TB...but as long as I am below 85% I usually let it ride.
A great deal for sure! I am now one step further for that 🌽 life! @Chuck is da man!
Short answer:
Assuming you already have a dual pump fuel system, log the car in the best possible air you ever think you'll see and if inj DC goes over 85% or fuel pump DC goes over 85% get bigger injectors. If you don't have dual pumps you won't be able to run E.
Longer Answer:
Based on my personal experience the answer is "it depends". I ran the ID1000s for a long time on flex fuel and full E85 with the dual pump drop ins, but what I started to see is that in really good air where the aircharge started to hit close to 2000 in logs the inj DC was going over 85% and fuel pump was approaching max as well. This is a tell that the fuel system is at its limits. For me this was rare as the air had to be just right for it to occur but fueling is something you don't wanna mess around with.
In my scenario I started keeping the ethanol to no more than E70 in that great air (which still gives you 95% plus of the benefit of E) and started keeping an eye out for larger injectors. I came across a set of ID1300x for a good deal and snatched them up.
Henderson
NV
2021 Challenger Hellcat
Short answer:
Longer Answer:
Hey Speedy!
I know this is an older thread but I wanted to get your opinion on running E85 with ID1050x/Fore dual pumps and 2.85pulley only. I live in Las Vegas.. the temperature rarely ever dips below 30F here. @ about 2000Ft elevation would these conditions put me close to the edge on this setup?
Probably fine but I'd data log just the same. My car had a 2.72 pulley.
Trackhawk, RS3, Golf R
Hey Speedy!
U need an Interchiller bro.....
In Vegas heat I'm not ever worried about the air getting TOO COLD. I'm worried about the other 95% of the time I'm driving it.
Dual ti285's and 1200cc Injectors have taken me to over 910whp on a mustang dyno. FBO, Ported blower/108mm, etc on E85 (exactly 85% ethanol too) with a good amount of room to spare. I'm coming close to running out of pump and/or injector at this point with further modifications.
If ALL you intend to do is a 2.85 and E85 you should be ok. ALWAYS log to be safe and until you have a trusted source ALWAYS TEST YOUR PUMP "E85"!!
I honestly dont know how anyone could drive a blower car in the Vegas heat WITHOUT an Interchiller. Ull get one hit and be heat soaked! E85 or or not. Its not something one SHOULD buy its an absolute MUST!
Ur 50 degrees cooler with an Interchiller and within (5) minutes ur back to same temps again. It also gives u a buffer when ur E85 isnt that great which can certainly vary from pump to pump.
Henderson
NV
That wouldn't be a bad idea!! I never push the car hard when its hitting triple digits outside. The mornings and at night is when I have fun during the summer months. I do have the 180 degree thermostat installed to help a bit.
Henderson
NV
There's one place in town Rebel Oil off Sahara and 15. They have pretty consistent E85R blend I have used before. Considering that you're making those big numbers on 1200cc injectors, I can make the assumption that my dual ti285 and ID1050x should fair just fine with a 2.85 upper. I will definitely take all of you guys advice and LOG everything.
The reason I want to keep my 2.85 upper is so that I can have two maps allowing me to switch from 91 -> E85 for track/fun. Of course I know if I want to lower my upper or lower pulley sizes I will need bigger injectors.
General rule is I can run my E85 track tune on any pulley I have. I can only run my inferred flex tune on a pulley that supports the base fuel (93oct) so I'm limited to somewhere around a 2.85 pulley. Prior to ported blower/snout it was a 2.79...basically most tuners generally accept a ~16psi limit for pump gas so whatever pulley puts you in that ballpark is your limit on a flex tune and yours may be lower given the 91.
