Iat question
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #61
Can get it on Summit, they stock them.
yep. davies craig ewp 150 18160. so which one is the 12 volt? never mind. thanks for the picture.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #62
oh that 10 amp add on the mechanic said it is an ignition relay to turn on the pump.
Yeah that’s what I said it was. Did you change it out to an actual add a fuse?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #64
No to be honest I do not know what an "add a fuse" is. Can you show me a picture?
I’m sorry, I did. Check a few pages back
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #66
Appreciated. And I looked it up. I see what it is. You crimp the wire into the existing wire on one end. On the other end there is a plug which allows for the fuse to be pressed into both the boot and fuse box. A fuse with connectors on both sides.
Yes, you put 2 10 amp fuses in it and it plugs into the fuse block of the car
Did the mechanic test the pump? Hard to believe it had an internal short, they’re stout pumps. Unless it went bad from that janky connection
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #69
He said they tried jumping it right at the pump itself. It would not turn on.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #70
got her back today. took a fifteen-minute drive to the biosphere 2 and back to my house. 30 minutes in 100-degree weather. i got on her three quarters of the pedal twice. the highest iat temperatures I saw was 139 with 122 as the iat coolant temperature. In a few hours I will check the coolant level in the trunk. if a little low i will add some water so there is no cavitation.
