Ok I had the same issue happen to mine , what I found was when you install them be sure in a triangle pattern install 3 just run them in to stop to align the wheel then install them ( I torque mine to 110 ft lbs , here is what I found out the hard way make sure you loosen all the lugs first before removing them , don’t remove one at a time without first loosening the others or they will sieze up
