Anyone try to fit the demon front crate wheel on a 6 piston hellcat/redeye?
Could it be machined to clear or spaced out? Where does it hit and by how much?
Thanks Scott
If you have the big Brembo's you are either gonna have to change the calipers or go a different route.
My 18x5 forgestars are -37 offset and barely clear the calipers.
Keeping in mind that the standard 18x5 Racestars are -20 and are very commonly used with a regular HC. The Demon fronts are also 18 diameter, but yes - absolutely verify that they have sufficient space on the inside of the barrel and spokes for the larger calipers.
I have a set of Hellraiser wheels that are a similar(5 spoke) wheel to the Demon wheels and I could not find skinnies that matched.
That would have saved me a pile of money.
Check out the drag wheel and tire thread in drag racing on this site.
