IC Chiller install & review
2ndgen
Orem
I know, it’s definitely not the norm. Not user error either. It’s possible they provided the incorrect pipe to an fittings but I doubt that
Some people think JIC and AN are interchangeable...
If IC chiller included JIC you can tell. The taper on the male fitting would be a different angle.
Thread Starter #363
To clarify, these are NOT fittings that were included in the kit or provided. These were self purchased directly from Vibrant for coolant lines only. I used the AN fittings instead of plastic ones.
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
My fittings leaked, as did others I bought. I finally called them and they told me they had some bad ones and switched suppliers for the correct ones. They sent me new ones and they did not leak a drop.
Thread Starter #365
From where, vibrant?
2022 Charger RE WB
I made a video detailing my installation, as I said I would. I am not a YouTuber, and I never do that. But, perhaps, it will help someone out. I think it is worth a watch. I have a lot of time into the installation. Enjoy.
Katy
2018 Trackhawk
Very nice! Watched it start to finish. Love the attention to detail. I was going to use oem style constant tension band clamps but will look into getting those oetiker clamps, looks cleaner.
Also love the way you have it plumbed (chiller OR stock exchanger) to take the load off the chiller in stock exchanger mode (I'm in Texas).
Just a question, but besides the cleaner look, any other reason for not using the foam insulation on the hoses?
Once your up and running, I'd love to hear if the braid on the hose reduces/prevents condensation from dripping.
