Who switched from 305/45r17's to 315/50r17's??
whos made the switch and what did you gain? Looking to make the switch over the winter.
I made the switch about two weeks ago and since I went ethanol I’m glad I did I’m able to hook with my most power now
While the 305 will work on a heavily prepped track (depending on power) the 315 will give a lot more consistent leave. Especially when the prep is less than ideal. I do think the 3.09 gear may be necessary with the added diameter of the 315. That of coarse depends on how much power you’re making and how slippery the track is.
I’m considering going back to my 3.09 but I’m enjoying being able to launch it for now lol
Also swapping out the factory springs to the HHP demon springs. Hopefully get this thing hooked up.
I did the demon springs and the lockout kit worked well for me
That was great advice you got on the demon (hhp) spring and bmr lock out kit !
This is the route I will be going once my current 305's are finished .
Yes it was indeed lol
When in Rome 👍
Your 305s are finished your already increasing your power your going to be kicking yourself if you try to hook in them next season
What do you mean I already increased my power ???
Better get the 315
motorhead
Ottawa
2019 Challenger HC Widebody
And give me your old 305s.
Really I might make you a great deal
My 305’s are smoked.
FFBOS
Mount Prospect
2016 Hellcat Charger
I am going to use the 315 for next season. I couldn't get the 305 to hook well with great prep. Tune was adjusted for it as well. I think it will help. We'll see how it does come spring.
I wonder if the 315's will help the 60' with stock boost cars or if these are basically needed when more hp or boost is added ? …..I do have 3.09's already.
FFBOS
Mount Prospect
I think so, especially if you can leave it RPM vs idle. I could only leave slow squeeze of the pedal off idle on 305's.
COLUMBUS
KS
Just a quick note. I switched and I had high hopes. But if the Track is crap, well then the track is crap. The 315's will not hook.
FFBOS
Mount Prospect
They will give you a better chance than the 305's no doubt though with "marginal" prep.
