Your drag tires, do you have beadlocks? I have found mine move so I don't balance them
They shake too much at the top end if I don't balance them and the weights started falling off.
No beadlocks.i tried balancing beads but they were too messy.
No beadlocks.
Mark them and see if they are moving. If they are don't balance them. That may be why it is shaking now cause the weights are in the wrong place
I tried not balancing them and it was bad. Thanks, I forgot to mark them this time.
Still looking to wire a kill switch on an M6 car. Switch mounted and hidden. Starter relay option ng as it can still be push started. Looking at the blue/orange fuel relay wiring that runs from trunk to fuel pump and looking to splice my switch into that beneath the rear seat delete. Now I see two blue/orange wires going into the d/s fuel pump. Any idea if it matters which one I interrupt with the switch? Thanks
Well it ain't a bomb so...take yer pick I guess...( I know..I'm an idiot)
Lize
Bury St Edmunds
United Kingdom
2019 Challenger WB Redeye
Filled up the TRX again, the low fuel light came on as I pulled in the gas station and it took £172 ~ $225. Thought prices had shot right up until I realised the tank is bigger than the Rebel 😂
Faffed about for ages trying to fit the bed step, it gets heavy after a while. Whatever I did it just wouldn’t fit and kept getting jammed on the chassis by about a 1/16. Trimmed it with the angle grinder and it slipped straight on.
I feel for you... : (
BP 93 yesterday,, filled up. $87. Now I have mechanical problems coming out of the collision shop. So, I had to give the shop the bad news after they called me wanting me to give them a perfect score on their cooperate survey. Well boys, we ain't dun yetster. Got emblems to put on and paint get a mechanic to fix this fan problem. Dun stepped in a pile of crap. They are going have to rent a dodge mechanic to fix this. My car looks very nice in the garage.
I took it's carriage up for an additional pair of tie-downs further out because they were to close to the splitter and a fuel can rack so that they don't roll around and damage the kitty.
Looked at it, in the same position it has been in since the first week of October, and really began to wonder if a pile of Benjie's would look better. I need to drive it soon, or my mind is going to go somewhere where it should not be!
Mine is there.
JRabq
$65 to fill the tank coming home today @ $4.89/gal.
Still my daily driver...piss on the purveyors of all this! Down shift for some burbles passing a Prius....pfffttt...not gonna stop my fun!
Colorado and the area is lagging a bit on price, but we did have a ~$.35 jump today from yesterday to about $4.30
Finally completed kill switch install...finally...
Drove it! It has been since early October. Using the OEM wheels early season with some Pirelli’s out back and Pilot Sports up front. It is running like the bad ass it is, and I remember. I need the larger tires and some heat!
Same as above. Took mine out for a while yesterday and took a run down to the beach. Great day for a ride. Although a little still cold here in NY I put my winter storage wheels and tires away and mounted my summer set.
388B729A-0306-4228-87EF-6ADD26C1F4F7.jpeg 83F81D13-E78E-4838-9769-6889438D9C0C.jpeg CE262B5E-AB41-479C-9374-0BEA50D7EE21.jpeg
I am going to have a glass of wine and think about it. Maybe a short jog down US 19. Make sure it starts.73 degrees.
Demoniccat
Hick glad to hear your back out with the cat. Long wait very similar to us northerners when our ride is hibernating for winter.
Yepper,,, this is our time to shine. Bradenton was a blast. Back to the car shop on Monday. They had to reorder the metal decals. Then I have to have em painted. Fan want come on so they are going to rework that. But thanks. Out and about.
having fun....is the reason we work like we do....you earned it...:cool::cool:
I'll hit em. Have hit a lotmore fora lot less.
