18" demon skinny rims
on a 2020 hc wide body, the stock skinny demon rims dont fit, because of the rotor size?
are there any other options other than changing the front rotors?
wondering if there are any other solutions?
anyone make a decent 20" knockoff that looks similar?
is it even worth it to worry about having the stock front rims and tires vs skinnies?
I thought it was the 3 piston brake calipers that made the difference?
They won't fit because the new Brembo's are HUGE. The Demon used the earlier smaller ones. E-Bay has all the 20" aftermarket wheels you could want. Copy and paste this : 20" Replica Demon Matte Black Wheel 20x10.5 5x115 25mm car Rim . It will come up. Or you could just type in 20" Demon wheels" and they all come up. I had a bad experience with aftermarket quality on a set of rims I bought a while back. Good luck on your search.
Oh, but if your asking "do they make a 20" narrow version?" I don't think so.
Porter
2019 WB Redeye
Yeah, the caliper is in the way. To make them work you'd need an adapter of about 1-in, which is a whole different story/risk.
Yeah, I was hoping for an oem rim, but if all I can get is a knockoff, then I guess there's not much choice.
I have the stock 20" rims on the front with 315s. Just wanted something narrower.
Thanks for the ebay info. That's what I was looking for, even though it's a knockoff :(
the rears are 18" x 11" demon rims
I was thinking of getting 315/40/R18 drag radials. any wider/taller/better tire choices that would fit the 2020 wide body?
