Stock IC pump flow rate / Davies Craig150
Does anyone know the stock intercooler pump gallons per minute, and it’s operating pressure (I know it’s pwm, but at 100% Duty cycle is what I’m looking for). Does anyone’s run a Davies Craig electric booster pump (ebp40, 9 gallons per minute) inline with their stock intercooler pump? Are there any issues with the ebp running when the stock pump is not? Most likely going with a ewp 150 and removing the stock pump altogether, but looking for some advice. Thanks everyone
Thread Starter #2
Bump
If I ware youz, aand I'ze beez me. I wood look at dis vary closey, cauze. If youz get too far out of wack. Youz culd pump 2 fast and whore dead head 1- 2 da utter. Ifster too fast youz will by pass da areas dat you are not coolen down but axtracten da heat. Too fast will snot keep coolant in da areas long anuff to extract da heat. Dead head will have da pumps goen against each utter. Pressure will beez way out of wack and youz will defeat you'll perrpuose. Beez careful.
So eliminate the factory pump
Well Unhooly 1, wished itster waz dat easy. You still hsve 2 cross reference da psi of da new pump 2 da 1 youz bee taken out. Like da PSI increase, supply and returd inlets and outlets. Da hose size which will all increase. Whore youz chazen ya'll tail. No guud. All hose & fittens sizes will increase 2 watt?? Don't kno. He needs 2 dew his home wurk.
That’s exactly what I’m trying to figure out lol, whole reason for this post
Bump
RGPIII
Bridgeville
DE
I ran a Rule 2000 pump in line with my factory pump. running from the trunk to the front of the car is a bit much for one pump in my opinion.
i agree i ran my factory pump with the ice tank ,when i wasn't racing i only had the factory pump running so the ice tank pump would not be running all the time
My current setup. Doesnt work that great. Working on a new idea now will report back with my results.
Mine has the external Davies Craig electric booster pump 40, which flows 9 gallons per minute. I want to upgrade it to davies craig ewp 150 which flows about 40 gallons a minute. I think the 150 should be enough flow to remove the factory pump altogether
If you want to share you super secret sauce with me over pm I’d appreciate it. I’m just trying to chase personal bests
Mine has the external Davies Craig electric booster pump 40, which flows 9 gallons per minute. I want to upgrade it to davies craig ewp 150 which flows about 49 gallons a minute. I think the 150 should be enough flow to remove the factory pump altogether
flowing faster doesn't mean it will cool better only means it will melt the ice faster ,slower flow will help the coolant stay cooler longer throughout the quarter mile ,you could leave your ice tank pump off and run only the factory pump inline with it and still get great results
I’ll report back in open forum on my findings
RGPIII
Bridgeville
DE
Mine with that setup and 40 bs of ice per pass would get down into the high 30's low 40's and end in the 80's on a pass.
See that’s the problem that’s a lot of weight. Plus weight of the lines
RGPIII
Bridgeville
DE
exactly, toss the lines and ice tank in the trash and put a chiller on!! I was simply helping the OP with his question. Not everyone wants to hear they are making a mistake.
Thread Starter #18
It’s not a lot of weight if you removed it elsewhere lol you guys and your grocery getters
Thread Starter #19
Probably still running sway bars and junk smh
RGPIII
Bridgeville
DE
it was over 80 lbs removed when I dropped the ice tank and lines. including the added weight of ice/water.
