How many of you use a foam cannon or foam gun?
  • Yes
    Votes: 10 71.4%
  • No
    Votes: 4 28.6%
  • Total voters
    14
StingrayZ51
Lindenhurst
Comet power washer and MTM foam cannon here with MTM wand from obsessed garage. Love the combo. I have a spare foam cannon I use just for the wheels. Use P&S wheels cleaner 1:1 in it. Works awesome.
Thinking about buying a cheap foam cannon just for P&S brake buster. Use a wand as well. Have green works pressure washer with DI water setup. +1 on obsessed garage. Thanks for sharing.
StingrayZ51
Lindenhurst
As you can see I have the IK foamer as well. Don’t wast your money the wand leaks. Get yourself a cheap amazon foam cannon like you said and use it for the wheels. My wheels are coated so I hardly ever have to use brushes. Spray on and rinse off.
PaVaSteeler
Mole
GreenWorks 1900 psi pressure washer and multiple foam cannons.
I use 3D Pink Soap, which is a pH neutral soap. Still playing around with mixture, but goal isn't simply to get the "foamiest" foam, but to lay down a solid coat so the soap has time to loosen and encapsulate any debris on the car.
I rinse, then foam, then rinse again. Then go to a two-bucket (2 gallons each) using Wolfgang's Uber Rinseless wash to wipe car down. Typically only need one (1) 16" x 16" Gyeon Silk drying towel to dry my entire car (except wheels, I do them separately).
71SixPack
Elizabeth
Been using a Chemical Guys cannon for a couple years now. Started with their cannon soaps but now using Griot’s brand. Foam it up, rinse and towel dry. Works great.
Same, this one...
https://www.amazon.com/dp/B00OA66IG0
762CAT
Somewhere in...
SC
Hellcat Challenger & Charger
I use that IK9 for my wheels and an MTM foam cannon for the rest. Recently started using Auto Fanatic products and I have to say they are pretty amazing. Wheel cleaner is great, snow foam is great but the 007 as a drying aid and quick detailer is other worldly. SOOO much gloss and helps maintain the slickness of my ceramic coating. Absolutely love it. I also have used his Secret Weapon with great success to include removing light scratches from between the tail lights on my black challenger and on the tail light section of my charger.
On a separate note I've been on an absolute quest to remove spots and blemishes from my carbon fiber stripes. I finally got them perfect and the secret was a magic eraser and diluted isopropyl alcohol in some tougher areas. I cannot believe how well it worked.
Bought a new pressure washer on a black friday deal & it came with a foamer. Looks pretty cheesy, but will be interesting to see how well it works.
we got cars up here that look like that...its called frost...
I use it on the Dually more than the car because the truck doesn’t fit through the car wash.
amazon cannon
Chemical Bro’s honeydew
NYCSRTATE
NYC
Charger Hellcat
Chemical guy's foam gun here and loving it.
Wow.....I feel so archaic. I still use a bucket and hand wash my car. I use my leaf blower to blow off the majority of the water quickly so it won't spot, then I can usually dry the remainder of the car with one microfiber towel. Then a separate towel for the touch-up dry on the wheels. I like using the leaf blower because it forces the water out of those crevices where it likes to hide and then suspiciously drip right after you wipe past that spot.
A few of my neighbors looked at me like I was crazy when they saw me drying the car with the leaf blower.....yet now they are doing the same thing.
B5Cat16
S
You guys let water touch your car? Not at my house.
