2.85 hellcat vs redeye?
Hemiride
Farwell
How would a hellcat with a 2.85 and a good tune on 93 compare to a redeye say from a 45mph roll? I'm not talking from a dig because that is more driver skill.
oilburner
coboconk
it would beat the redeye.
Hemiride
Hemiride
Farwell
That surprises me a little. A 2.85 cat makes what 13 to 14 pounds of boost? Doesn't the redeye make 15?
Blkout
Warner Robins
2.85 Cat should make around 15psi. Since the 2.85 Cat will require a tune as well, if the tune is done by a good tuner, the 2.85 Cat would have a slight power advantage and the Redeye weighs just slightly more. Advantage 2.85 Cat, although I wouldn't say its much.
oilburner
coboconk
will know better tomorrow going to napierville an there will be 2 stock redeyes in the group, will let you know an I only have 10% ati with OST tune. if I had a 2.85 with out the 10 % I know for sure it would do the job.
Mine has the 2.85 and makes as high as 15.5 lbs of boost at times but mostly just 15 went as high as 15.5 with today’s runs
Hemiride
Hemiride
Farwell
I'm about 800 to 1100 ft above sea level.
That would reduce my boost wouldn't it?
I would imagine so but cold air will help too
I was at 500 today
It’s ok hemiride a redeye would beat me at a 45 roll because I’d smoke the tires on mine lol
Hemiride
Hemiride
Farwell
What do u feel is the best street tire?
I like my firestone Indy 500 tires they handle very well and definitely have better traction now I’ve added more hp and I can break them loose as well as high as 65mph
Hemiride
Hemiride
Farwell
Who tuned your car?
Curt @dusteroff tuning
My car is a happy car now that he tunes it
Hemiride
Hemiride
Farwell
Interesting
I'm planning to go with a litens 2.85. Demon injectors. Blower spacers and thermo blanket next spring. Seriously considering Curt
I’d definitely recommend curt for sure
Only thing I’d change would I’d use 1050 injectors
Hemiride
Hemiride
Farwell
Thread Starter #18
R U on e85 or 93?
I've read that curt is the guy for e85.
I'll be running 93.
I have a 2.85 pulley a tune and Demon injectors on my 2015 Hellcat. As soon as my 2019 Redeye is broke in I’ll let you know. Right now my 2015 feels stronger.
R U on e85 or 93?
I'll be running 93.
Mines on 93 but your right curt is the E85 guy
